Hi all i got radiator with broken bleeding valves(see photo) . Is there any way to change them for new ones or i need to buy new radiator? Thank you
Sometimes the vent key has the square hole recessed a bit. If you file the end down by a couple of mm you may find it grips the bleed screw better.
