Is this portable vice working as intended?
Discussion in 'Screwfix' started by phario, Jul 30, 2020.
Tags:
  1. phario
    phario New Member
  2. phario
    phario New Member
    There is a bolt you can try and tighten on the base, but it seems too poorly machined. When the rotating plate is not screwed in, there is too much of a gap. Basically when you screw in the rotating plate, the whole thing then tilts at an angle.
    [​IMG]
    For this to work, the centre bolt needs to be machined well enough that when the plate is free to rotate, there is only a small gap. This means when the plate is then screwed in, there is not enough of a gap for the device to tilt.
  3. Severntrent
    Severntrent Screwfix Select
    Take it back NFFP
