JB alternatives
Discussion in 'Electricians' Talk' started by Kirby Castle, Apr 28, 2006.
  1. Kirby Castle
    Kirby Castle New Member
    I really don't like 3 plate - it can be a real pain with "modern" non pendant lights and since JBs under the floorboards are not acceptable, what other methods/tricks/tips do you all use?
    Steve
  2. madmaz
    madmaz New Member
    they are acceptable if you have access to them and do a sketch showing there location etc.
  3. Lokkars Daisy
    Lokkars Daisy New Member
    :'( sorry but
  4. madmaz
    madmaz New Member
    sorry but what ?
  5. steve CF
    steve CF New Member
    On most new builds now they loop in at switches and take just one cable to each light fitting.
  6. tellondon
    tellondon New Member
    So you have the 3 plate system at the switch effectively Steve? I always thought neutrals at the switch were frowned upon?
  7. madmaz
    madmaz New Member
    not if they are identified correctly and not switched, via a single pole device
  8. steve CF
    steve CF New Member
    its very common practice now on new builds.
  9. Lokkars Daisy
    Madmaz not you but Kirby ,looping at light switches is yonks old ,how can you ask the question Mr Kirby ?
  10. tellondon
    So you just put the neutrals in a connecter block?
  11. madmaz
    madmaz New Member
    no bother had me confused for a mo !!!
  12. madmaz
    madmaz New Member
    yep simple as that.
  13. steve CF
    steve CF New Member
    yep connector block on three neutrals
    its a very good way to supply external light as well but usually i install a double pole switch for external lights.
  14. tellondon
    Yea i know how to do it but as i mentioned i got the impression neutrals at the switch were frowned upon, i actually saw that `neutrals at a switch` thread recently but ignored it because i `thought` i knew the answer, ive just done a rewire when i knew they wanted lights that you couldnt make a 3 plate connection in so i put JB`s above the ceiling , thats still ok if they are accesible isnt it?
  15. steve CF
    steve CF New Member
    yes if there accessible
    BUT dare i mention the word "NICEIC" say that if there is a carpet over the floor then the J.B. is not classed as accessible.
  16. Kirby Castle
    so how can a JB be accessable - also considering that they need to be screwed down and the cables clipped.
    I came up with one solution - that is to fit the JB and then solder the wires in on each terminal. This then doesn't need to be accessable.
  17. steve CF
    steve CF New Member
    good idea
  18. tellondon
    Im with the NICEIC Steve, how do you find out about all their expectations over and above what the regs state? Only way i get information from them is via the connections magazine sent through a few times a year, asked them to send me info about the trust mark scheme over a month ago but still havent heard anything
  19. madmaz
    madmaz New Member
    sounds good to me too
  20. steve CF
    steve CF New Member
    its in the NICEIC technical manual
