Hi there, I've plasterboard my loft out, there were some really nasty angles up there, and I may have the odd gap between boards,i want to know what is the best way to close the gaps up before I get the plasterer in, doing as much as I can to save some dough. I would presume I'd need to put skrim tape over gaps and fill with some king of filling adhesive, I want to k ow what's the best/strongest. Cheers for any help received
How big are the gaps? Realistically the proper method would be to just re-cut some plasterboard and replace. However... when i was doing my own hall and i had a couple of gaps, i did mesh and fill with bonding, and it has worked perfectly fine. Not sure how happy a proper plasterer will be though as ultimately he'll be the one presumably guarenteeing the work
Just expanding foam the gaps and cut it back once dry. Once plastered you’d never know about any gap.
Hello mate, they're not too big and the plasterer is a work mate, it'll come with a 10 yard gaurentee cheers for advicr
