Junction box for mains ring ?
Discussion in 'Electricians' Talk' started by Coolgit, Feb 13, 2004.
  1. Coolgit
    Coolgit New Member
    Is a heavy duty 30 amp junction box ok to connect 2.5mm cable running from a 32 amp fuse consumer box ?
  2. Notan Xpert
    Notan Xpert New Member
    A heavy duty 30A will be OK or even the standard three terminal type, 30A again. If you are spurring off the ring do not cut the ring main cable just strip the insulation carefully and lay the cable into the box.
