Karcher K2 Pressure Washer - pulsing problem
Discussion in 'Landscaping and Outdoors' started by Jitender, Mar 21, 2017.
  1. Jitender
    Jitender Well-Known Member
    I'll have a look at that in the weekend.
    Also noticed there is a control knob on the front of unit, only realised when posting the picture.
  2. Joe95
    Joe95 Well-Known Member
    Is it any good? I didn't even know Makita did pressure washers.
  3. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    For heaven's sake. The answer was given. Leak = pressure drop = starting = pressure = stopping ad infinitum.
    Leak is after the pump, so = control head.
  4. sospan
    sospan Well-Known Member
    Very, good excellent power and long reach pole. Like the Nilfisk ones I can use it to strip flaky paint off timber
  5. Jitender
    Opened it up today. There is a leak inside the unit.
    I cleansed out the water inlet filter as well.
  6. Phil the Paver
    Put it all back together, it still didn't work so skipped it along side all the other Karchers.
    :p:p:p:p:p
  7. Phil the Paver
    Having said the above, I jet washed the patios today, but my petrol jet wash was playing up, wouldn't run for more than 10/15 seconds.
    Sussed it out though, it was the low oil switch playing up, so disconnected it and away we went 4 hours solid jet washing. :D:D:D
  8. Jitender
    Its all back together now.
  9. Phil the Paver
    Working as well. ??? :):):)
  10. Jitender
    Just the same pulsing problem.
  11. Phil the Paver
    So #26 is right then :D:D:D:D
  12. Mr. Handyandy
    I bodged mine. Couldn't find a control head for less than £26, so wasn't having that. It had a leak in the control switch pot(the one that is pressurised and activates the stop switch when trigger is released).
    I completely blocked the pot from receiving water. I attached a short length of hose and a stop-valve to the main hose inlet. I attached a handle to the valve. I attached a round handle to the main on/off switch, and connected that via a stiff wire to the valve handle. I fixed the trigger on the lance to permanently on. Now I attach the garden hose to the valve, and turn it on and off with the valve handle which in turn turns the on/off switch. Bit clumsy, but works perfectly(although not automatically).
  13. Jitender
    Decide to take it apart. got nothing to loose.
    When I undid the 4x large bolts on the housing oile leaked out. Should have positioned the unit up :oops:
  14. KIAB
    KIAB Well-Known Member
    And what did you find.:)
  15. Astramax
    Astramax Well-Known Member
    4 woodlice and an earwig!
  16. Phil the Paver
    That its still a Karcher, so it's still carp. :p:p:p:p:p
    KIAB likes this.
  17. Jitender
    I'm an engineer in the making...... cough. I mean breaking! :D
  18. koolpc
    koolpc Well-Known Member
    She found a threepence!
  19. Dr Bodgit
    Dr Bodgit Well-Known Member
    I am an engineer (by degree). Always learnt stuff by taking something apart and learning how it goes back together again.
  20. Jitender
    It's quite fun taking things apart. Don't know If I can get it back together again :oops:
    Going to clean up the 3 heads as think there are seals here.
    The video I posted earlier from e-spares say sometimes the plastic casing cracks if the pressure washer is left out during winter which could have been the cause.
    When finishing with the pressure washer is it best to turn off the garden tap then press the trigger to get rid of all the water or is there another process that needs doing?
