Audi will put U right, but for what it's worth it seems very easy to lay from watching the three floors I've paid for. It's very hard wearing and holds it's looks well under heavy traffic. It's the stuff you see in places like M&S, The Orange Shop etc etc etc.
i lay saftey flooring..vinly..r u laying it on the flat..or up the cove???if on the flat i lay slc first then use BALL adeshive not bal..if up the cove u will need heat gun and attachments for internal and external welds..
get a bit of 18mm ply some contact adeshive and a bit off carpet..good thick carpet..cut ply to a size of about 1ftx1ft an wrap carpet round it half way either side with contact adeshive..use this to run over vinly works a treat an cheap...
when adeshive on floor leave to go tacky before laying vinly...half room at a time or if u hav wee arms smaller areas...best adeshive is BALL...small teethed trowel u will need an try an keep it up right not like putting down tile addy
It's not as easy as you think....It's OK if you are experienced at laying vinyl professionally but if not you could be making an expensive mistake!
It's a piece of isssssssssssssssssss Roller?????? nah for a small job carpet on ply, nice big brush, whatever. It's just little bits of vinyl!!!!!!!!! Only hard if you have some big fancy design and then it's more time consuming than hard.
Here you go, a quick lesson. Ply the floor, screw down well, min 150mm centres, all c/sunk. All joints in ply and screws feather finished and rubbed down. Apply adhesive, f-46 pressure sensitive using a 5mm notched trowel and flatted out using a med acrylic paint roller. Allow adhesive to dry to a tack, you will see colour change. Apply tile. Some will say you need a guilotine to cut tile, not true, score the face of the tile and bend (it will break the front) then cut through like with plaster board. It's a doddle
And what a great warranty it is "providing the material was installed and maintained properly, and used as intended and recommended. Wear out is defined as a complete removal of pattern and/or color from normal traffic and maintenance. In the event wear out occurs within specified product warranty time frame of the date of purchase, Karndean International will repair or provide replacement materials only. Furthermore, Karndean Tiles and Planks are warranted to be free of any manufacturing defects. Any other implied warranty that the goods shall be fit for a particular purpose is hereby excluded. Karndean accepts no responsibility for faulty installation or incorrect maintenance. This warranty does not include the following: 1. damage due to: stains, burns, cuts, gouges, scuffs, scratches, indentations, and other accidents or abuse; 2. discoloration or bond release from hydrostatic pressure or excessive moisture caused by such things as flooding, plumbing and appliance leaks; 3. installation of flooring over particle board, chipwood, or presswood; 4. installation where material was not installed with Karndean adhesive in accordance with Karndean specifications and recommended usage; 5. dissatisfaction due to improper installation, maintenance or irregularities; and 6. reductions in gloss or build up of residue due to improper maintenance or normal wear and gloss reduction from use
