Kick boards
Discussion in 'Carpenters' Talk' started by Alan bell, Oct 10, 2017.
  1. Alan bell
    Alan bell New Member
    just had new flooring fit in kitchen (vinyl planks) now need to fit new kick boards but they need the thickness off he new floor taking of, I did a shorter board with a belt sander but it took an age to do. What would you use the board is apx 3 m long high gloss.....thanks in advance.
  2. DIYDave.
    DIYDave. Well-Known Member
    Yep sanding will take an age indeed !
    Circular saw, fine tooth blade, at least 80 teeth, cut with finished side upside down and run the saw against a clamped straight edge
    Could also use a track saw, basically the same as above but great for long straight cuts
    Are you fitting a seal strip to cut edge at floor junction ?
    Alan bell likes this.
  3. KIAB
    KIAB Well-Known Member
    Track saw a lot easier than a running circular saw with a parallel guide along a length of kick board.
    If you use circular saw, put kick board cut edge up,any discrepancy will will be hidden.:oops:
  4. Jord86
    Jord86 Well-Known Member
    A handsaw will be fine if you're a DIYER as you may not have a circular or track saw. Buy a saw with at least 10TPI (teeth per inch), place masking tape tightly over the area you are to cut, pencil a line and cut with the saw, taking your time to be as accurate as you can. You can also score the line with a Stanley knife first to aid cutting it if you want. Peel the masking tape off and you should have a clean cut. Make sure you cut from the face though, doing it this way.
  5. kitfit1
    kitfit1 Active Member
    @ Alan Bell, if by any chance you bought the Plinth from say B&Q you can always take it back and ask them to rip 10mm or whatever you need off of it.
    @ Kiab, a track saw along a bit of plinth 150mm wide would be a nightmare lol.........................what ya thinking ? o_O
  6. Mr Rusty
    Mr Rusty Well-Known Member
    why? I use mine on narrow boards frequently. As long as both sides of the track are equally supported (usually by using the other board that needs cutting) and you use track clamps it's a walk in the park. Works for me.
    GoodwithWood and Alan bell like this.
  7. DIYDave.
    I’ve gotta reply as it was me who suggested a circ saw or track saw;
    I’m only diy so have a cheapo Titan track saw but for me, it cuts really well and after some adjustment, very accurate
    Often use on narrow timber with no probs, just place same thickness timber either side and clamp down so uv now got a wide, even base for the track to sit on. Always cut onto a ‘sacraficial’ board underneath and set blade 2mm deeper to give a clean cut. As I say, I’m diy but works for me :)
  8. CGN
    CGN Well-Known Member
    Plunge saw is,a great bit of kit...if you have one to hand :)
    Failing that, a nice sharp fine tooth hand saw as Jord mentioned will have the job done in minutes and will cost not much more than a fiver.
  9. longboat
    longboat Well-Known Member
    I like the belt sander approach. :D
    There’s not much you can't do with a belt sander given enough time.
    Alan bell and CGN like this.
  10. Alan bell
    thanks for all the replies, I've not done it yet but I think the 3m length is from B & Q so may go down
    that track and see if the will trim it for me.. didn't think they would touch it being such a small amount
    to trim of..
