Kingspan solar and unvented cylinder noise
Discussion in 'Plumbers' Talk' started by Daz Franklin, May 13, 2018.
  1. Daz Franklin
    Daz Franklin New Member
    Hi... my kingspan solar hot water system and range tribune unvented cylinder is making a weird groaning/jet engine noise when the system modvlvs pump is circulating, is this normal? .. any ideas what it could be or advice? Both getting serviced end of may and not noticed it until the sunny weather arrived. Thanks in advance. Ps tried to upload a video but failed.
  2. I must be sad
    I must be sad New Member
    They work all year round so nothing to do with season
    Sounds like pump is stuck
    Daz Franklin likes this.
  3. Boilerdoktor
    Boilerdoktor New Member
    What’s the system pressure and have you got circulation
  4. Daz Franklin
    2 bar ... pump symbol is spinning but almost a howling noise every 1-2 mins .. switched it off pending service, worried it does more damage .. cheers
