Hi all I’m trying to work out how a corner goes in my kitchen. The plan shows an end panel then space the ES, trouble is I can’t work out how to do it. Pictures explain better
you just boxing in? if so just visualise it as a very small cabinet with a door and set the front out the same as a door.
So I did it like this, I left the edges flush not sure if this was correct. I’m looking at doing the other side of room. Does it have to be symmetrical? units run along a long wall so I’m guessing it should be pretty near. But should I aim for that? thank you for replies
