One of my cupboard doors has had a loose hinge for a while, I'd done a quick 'botch' repair by unscrewing where the hinge was attached to the carcess of the cupboard and packing the hole with match sticks and screwing it back in. However its now come away completely and the chipboard has flaked away leaving 2 holes about 6mm in diameter. How would be best to fill these holes? They are the usual 35mm concealed hinges so I can't easily just mount the hinge lower on the door. Thanks in advance.
Well it is a highly complex and technical problem that needs the minds of the worlds greatest engineers to resolve it.....
if there is a unit next to it you can use 30 maybe 35mm screws and fix thru to the next unint. unless there is a hinge the other side for that unit also.
If there is a corresponding hinge on ajacent unit, I remove the screws and put and bolt and nut through them both and tighten. Nothing goes nowhere then.
