Kitchen Cupboard Help Needed!!!
Discussion in 'Kitchen Fitters' Talk' started by Stevie dee, Apr 8, 2018.
  1. Jord86
    Jord86 Well-Known Member
    +1 for everything Goldenboy says above.
  2. Stevie dee
    Stevie dee New Member
    Yes this is the preferred option..thanks a lot for the advice
    Great forum here cheers guys
  3. Stevie dee
    So on this pain of a bracket, I've got one hole fixed into the brick correctly but can i use a standard brown plug on the other two holes( which will obviously be plaster only) just to give it additional support??
  4. Jord86
    Have you tried my wooden spike method?
  5. Stevie dee
    One the one location yes it worked great...but the other one the brick crumbled away....cant see what the problem is but i think pinning either side as suggested is a good plan.
  6. Jord86
    I normally insert the spikes with a dab of polyurethane glue on it for it to expand and take up any gaps and solidify everything, but I assumed you didn't have any to hand. As long as the ends of your units are well supported, screw the middle unit tight to the others and as long as you don't fit a baby elephant in there, you'll be fine.
    goldenboy and Stevie dee like this.
  7. goldenboy
    goldenboy Well-Known Member
  8. greenback78
    greenback78 Member
    What about using GripIts? I’ve found these a good backup for this type of thing.
  9. Jerry1
    Jerry1 Member
    I use a 6.5mm bit brown plug tap plug in with screw as said above
  10. Stevie dee
    Thanks to everyone for their comments. All really useful and job done...cheers
