kitchen extractor hood fitting
Discussion in 'Electricians' Talk' started by BrianR66, Oct 29, 2021.
  1. BrianR66
    BrianR66 New Member
    Does a cooker hood have to have an isolation switch or can you just wire into a 3 amp plug?
  2. Comlec
    Comlec Screwfix Select
    Putting a plug on it will be fine.
  3. BrianR66
    BrianR66 New Member
    That's great, thanks so much!
  4. candoabitofmoststuff
    But I would make it so you can isolate, easily, somehow... If smoke starts coming out of it you want to be able to cut power to it without having to take it off the wall!
    Cando
    Teki and BrianR66 like this.
  5. Bazza
    Bazza Screwfix Select
    Just pull the plug out, or switch off at the socket. Simples!
    I am assuming the socket will be readily accessible.
  6. BrianR66
    BrianR66 New Member
    Yep :) mind you the tiny 1M cable is a potential pain in the ****
  7. candoabitofmoststuff
    Big assumption!
    Cando
