Kitchen Hood Extractor 100mm or 150mm Core
Discussion in 'Kitchen Fitters' Talk' started by kiteboy, Oct 26, 2018.
  1. kiteboy
    kiteboy Member
    Hi
    Just thinking about what extractor we need for new kitchen in new extension - I see that most of the extractors that Ive been looking at are 150mm
    Just spoke to sparky and he said put a 150mm to 100mm reducer on there and cut the hole through the wall at 100mm
    Is there any issues with that?? I gather a ridgid pipe is better than the corrugated stuff??
    Thanks for any tips
  2. KIAB
    KIAB Well-Known Member
    Bad idea!
    Go for 150mm every time, will allow you to use a wider range of extractors,even those with higher extraction rates, using 100mm can restrict extraction,effiency & make hood noisey.
    And use 150mm rigid ducting, put a very slight fall on ducting to allow any moisture to escape,rather than laying in ducting.
  3. kiteboy
    kiteboy Member
    Argh so its a slight fall - I was going to go for a slight rise to allow air to escape - ok thats fab - thanks
  4. KIAB
    Just a few mm's,all that's needed.
  5. kitfit1
    kitfit1 Well-Known Member
    Never use 100mm ducting if the native outlet size of the cooker hood is 150mm. It will reduce the ability of the hood to shift air by 30%, it will also increase the noise the hood generates significantly. Sparky's know nothing about hood ducting or kitchen fitting, so ignore him.
    Jord86 and KIAB like this.
  6. kiteboy
    kiteboy Member
    Thanks all - will be looking to buy a 152mm core bit then!
  7. KIAB
    Hire one,about a fiver.
