Hi there,
So I have thrown several methods of drain cleaning from each side of the sink which has improved the issue but it still persists.
When draining larger amounts of water from the kitchen sink, or when the washing machine drains out, water starts backing up and coming out at point one.
Also as water does drain away lots of gurgling from point two.
Thinking drain is clear but a vacuum is in there somewhere stopping water from draining quickly.
Dismantled as much as I can and cleaned lots of crud out. Also used auger from front of house and cleared out a load of gunk and smaller auger down the pipe under sink as far as I can.
