Kitchen Wall Cabinet Adjustment Screws
Discussion in 'Kitchen Fitters' Talk' started by TragicMagic, May 10, 2018.
  1. TragicMagic
    TragicMagic New Member
    I could just pull them off the wall and find out for sure... but that would make too much sense ;)
    On a standard wall cabinet adjuster one adjustment screw does vertical and one does horizontal.
    Question is what should clockwise on each on do? Vertical clockwise higher and horizontal clockwise towards the edge the adjuster is on?
  2. Dr Bodgit
    Dr Bodgit Well-Known Member
    One screw will pull/tighten the cabinet against the wall (clockwise tightens), the other screw will raise/lower the cabinet (clockwise raises most likely).
    Best way to check is take the cabinet off the wall and check by turning the screws and seeing how the hanger moves.
    KIAB likes this.
  3. joinerjohn1
    joinerjohn1 Screwfix Select
    As the doc says, one of them will tighten it back to the wall. The other one is only for vertical adjustment. Horizontal adjustment is made by loosening the cabinet slightly and physically moving it sideways. ;)
  4. TragicMagic
    Was getting fussy over them being about 0.2mm out of whack at the top but all sorted now :p
    Thanks for the replies
