Kitchen wall fixing component
Discussion in 'Kitchen Fitters' Talk' started by D6277n, May 1, 2022.
  1. D6277n
    D6277n New Member
    We've been given a load of old kitchen wall cupboards which we're trying to hang in our utility room.
    Unfortunately one of them is missing a small part of the wall bracket mechanism. It's a rectangular threaded washer, 10 mm X 5mm. When threaded on the bolt it's part of the mechanism which tightens the cabinet against the wall and it also stops the metal wall hanger from pulling out.
    Does anyone know where I can buy these?
    Thanks,
    Chris.
  2. WillyEckerslike
  3. Hausfix
    Hausfix Well-Known Member
    Could you post some photos of the actual bracket it came from? I’m sure I can come up with an alternative solution if I can see what you have.
