KMF's and Electric Meter Box Classification
Discussion in 'Electricians' Talk' started by PlumbyGas, Jan 12, 2018.
  1. PlumbyGas
    PlumbyGas New Member
    800+ Plastic KMF switches or Plastic cased fused isolators being used to protected tails feeding CU over 8m away.
    Idea was new connected meter, tailed into KMF then onto CU.
    Has been flagged that KMFs are plastic therefore cannot be connected to, Meter company want to install additional DP isolator then sparks to attach from that to KMF.
    However also in the meter box will be all equipment associated with solar panels simply know room.
    Now if the meter box was deemed as a non-combustible enclosure the KMFs are fine how are they classed?
    Anyone have any input?
  2. Risteard
    Risteard Well-Known Member
    Flagged by whom?
    An isolator in an enclosure is not a similar switchgear assembly to a DBO certified to BS EN 61439-3 so I would not consider the Regulation to apply to that scenario.
  3. stateit
    stateit Well-Known Member
    UKPN and meter companies have connected up KMFs and Wylex REC2s that I've put in meter boxes...
    I've phoned ahead to say I'm "doing it and that it will be OK, won't it?"
    If I understand correctly in your case (800+), then why not put the KMF in the meter box?
    I prefer Wylex REC2s, by the way...
