Knotting showing through
Discussion in 'Painters' Talk' started by Shawt, Apr 12, 2019.
  1. Shawt
    Shawt New Member
    About 8 or 9 years ago I carefully treated all knots with Langlow Knotting stuff and undercoated and finished with Dulux Gloss white. Now the knots are showing through, particularly where exposed to sunlight. Should I sand right back to the knots and re-apply the knotting solution, or simply key the gloss, apply solution and then gloss?
  2. Davebuilder
    Davebuilder Member
    Zinster stain block
  3. Astramax
    Astramax Well-Known Member
    Sand it down and paint over and beyond the knots with Zinsser BIN, it is a high adhesion shellac based primer which will cure your problem. Read and follow instructions as detailed on container.
  4. Wayners
    Wayners Well-Known Member
    Got so frustrated with my pine stairs I coated the lot in aluminium primer. 2 undercoats and then satin... Zinsser bin will be your best bet x2 over knots unless there are loads.. Maybe aluminium primer in the sunny spots? Stir it well as the aluminium becomes solid at the bottom and its a gray colour hense it's a pain to get white but nothing with ever get through
  5. gac1967
    gac1967 Member
    The new Smith and Rodger blockade is better than Zinserr bin in my opinion, goes on easier and has less smell and its cheaper, and all jobs I have used it on have been spot on with no problems.
  6. Astramax
    Who stocks it?
  7. Shawt
    Shawt New Member
    Thanks for the advice, good to get it from those who know.
    All I have to do now is get on with it!
  8. gac1967
    gac1967 Member
  9. Astramax
  10. gac1967
    gac1967 Member
