There's only five terminals and it's supposed to be a 2 gangtwo way marked A and B communication cables and L LI L2
I have wired similar devices. Some questions I guess you’ve read the instructions? Is there something you don’t understand? Is this new wiring, or are you replacing existing switches? If existing, post pictures of the existing wiring. If it is two way switching, what are you putting in the second switch position? Another kunoq? Or something else? Answers to the above and a copy of the instructions will help.
Its existing wiring strapper connecting them going to another know can't work out how there five terminals on a 2 gang 2 way either
If its like others I have done, then they are not wired the same as standard 2-way wiring. Thats why I asked those questions. Need: answers to all of the questions above, copy of instructions, photo of existing wiring & then should be able to sort you out.
