Often the case when you have new carpets fitted that the doors will need trimming afterwards
Now if you’ve had in carpet fitters, fair enough, they ain’t gonna trim the doors and it’s left down to the homeowner to then source someone else to carry out this task - that’s acceptable
But you’ve used this firm for painting and decorating and now laminate floor fitting. So you would assume some degree of woodworking / carpentry skills would be evident and even required
Same as if you’ve laid laminate yourself as a diyer. Takes some degree of skill to pull of a neat job. The bulk of the floor is easy, it’s the fiddly bits around skirtings, doorframes, pipes, etc that really separates the good from the bad
If this outfit has taken on a professional paid job to lay laminate, then they ‘should’ be able to trim down a few doors
Yes I agree this should be charged as an extra per door, possibly a better rate if there’s 5/6/7 or so doors that all need trimming
But this should be made clear at the first site visit and put down in writing in their estimate / quote
To leave you on the lurch and say we don’t trim doors is rather unprofessional and clearly shows them as chancers
If your happy with their previous decorating jobs, then that’s great and hopefully they do a good job
Sounds like they’re trying to cover all bases and be multi trade when really they should stick to what they know
Again, those nails in Scotia trim tell you all you need to know about these guys
Good luck
