Landing light won't turn off
Discussion in 'Electricians' Talk' started by Andrew taylor, Mar 16, 2019.
  1. Andrew taylor
    Andrew taylor New Member
    I'm replacing the down stairs hall light switch ,two switches and one upstairs. Just replaced wires in new switch (all red) now when I turn landing light on from downstairs ,it won't turn off upstairs. Also it won't turn on from upstairs. On the new switch it says at the top 1 way then next screw just says 2 the bottom is just single holes in each one, saying com. Help guys please
  2. unphased
    unphased Screwfix Select
    You've mixed up the wires in the switch. There is no way of knowing what you have done without test equipment to find which wire is the feed to the switch. Just try swapping the wires around until it works. You can't cause any problems because all the wires are lives.
  3. MGW
    MGW Well-Known Member
    In the main two way switches have a three core cable liking them and each terminal uses same wire, so if L on one switch is red then also L on other switch is red.
    One switch will have two extra wires, these normally go to L1 and L2 so Com or L depending on make of switch will only have one wire.
    There are other ways to wire, but above is a common way.
  4. spirits are real 2016
    spirits are real 2016 Active Member
    you did buy two way switches and not one way didn't you photos will help us help you.
  5. Jitender
    Jitender Well-Known Member
    The switch could be an intermediate one
  6. Philip Hyde
    Philip Hyde Member
    not if it has a single hole at the bottom.
  7. MrA
    MrA Member
    Trial and error with the cables or get a sparky to test and correct, this happens more times than you can imagine. With the benefit of hindsight you should've marked the cables (not helpful I know). I'd should a millionaire by now with millionaire with my hindsight skills.
  8. MrA
    MrA Member
    Trying not to troll and failed, single hole at the bottom, (teehee). My bum is a light switch! :D
  9. Andrew taylor
    I'm not sure it's by mk packet says 10amp double two way .
    I did take a pic but the old switch was old and had four holes at the nottow two either side and one either side at top.....unless there the other way round on this one ?
  10. Andrew taylor
    I'll have a look
  11. Pollowick
    Pollowick Well-Known Member
    That picture plus one of the new switch may help.
  12. Philip Hyde
    Philip Hyde Member
    Why is pointing out its impossible for it to be an intermediate switch Trolling?? It's got 3 holes in each switch Intermediate has 4! Or didn't you know that?
  13. MGW
    An intermediate switch can be used as a 2 way, and a 2 way as an off/on. Also often the same casing is used. So two holes either end could still be a two way or on/off you would need to count terminals. Even then some switches have linked terminals.
    As said pictures are good, we are all guessing, could be simply wrong type of switch fitted, and whole idea of intermediate has been superseded with the electronic switch with master and slave where you can have multi slaves connected to one master. Even the instructions that come with the switch don't help, I bought a master switch it did not call it a master and can see the S terminal but nothing to say what the S terminal is for, that's only written on instructions for the slave. And with a switch with an S terminal the comment "Just try swapping the wires around until it works." is daft as they could destroy the switch.
  14. MrA
    MrA Member
    Apologies, it was me trolling, just wanted to add a childish joke. Clearly I failed.
    Philip Hyde likes this.
  15. Andrew taylor
    Hi guys thanks for the replys and help I persviered and now it works . Looks like being an engineer got me nowhere here lol thanks everyone
  16. spirits are real 2016
    in the end you saw the light.
  17. Andrew taylor
    Lmao certainly did
