Larder unit
Discussion in 'Kitchen Fitters' Talk' started by big_bad_bob, Oct 24, 2006.
  1. big_bad_bob
    big_bad_bob New Member
    I have to fit a larder unit into a corner. The side wall is out of true such that if I set the unit vertical there will be a gap of about 1 cm at the bottom, nothing at the top. What is the usual solution to this problem? I don't really want to leave a gap. If I scribe an infill to fit the gap I'm worried it will be very fragile and I'm not sure how good it will look. I've got a small amount of room to play with, so I could move the unit sideways an inch or so and put in a slightly wider infill if people think that would be better.
    Thanks,
    Bob.
  2. Jonny Round Boy
    Jonny Round Boy New Member
    As you aluded to at the end of your post, a wider filler (say 35mm at one end & 25mm at the other) would look better than a filler 10mm wide at one end tapering to nothing.
    It's personal opinion, but I'd move it over the extra inch.
  3. britishblue
    britishblue New Member
    I agree with JRB.
    BB
  4. gint
    gint Member
    me too
  5. flying sctsman
    flying sctsman New Member
  6. big_bad_bob
    Thanks guys. I'd pretty much decided that it would have to be done that way, but it's nice to get another opinion or two.
    Cheers,
    Bob.
  7. sinewave
    sinewave Screwfix Select
    Brown Gaffer tape?
    No?
  8. Jonny Round Boy
    I thought gaffer tape only came in black & silver...?
  9. sinewave
    I have White & Green on the Van at the mo, as well as Black, but no Silver! :(
  10. flying sctsman
    anyone spotted the spark ;)
  11. sinewave
