Large angle grinders
Discussion in 'Builders' Talk' started by teabreak, Jan 31, 2019.
  1. teabreak
    teabreak Screwfix Select
    Hi I am looking for a large grinder to cut concrete paving slabs, only diy I have a path and greenhouse base to lay at home. My 4.5 grinder will do it with a diamond wheel but needs to be cut from both sides. I want one that will cut through in one, any recommendations please?
  2. Dam0n
    Dam0n Screwfix Select
    I have a Bosch blue 9" and it's excellent. 100% recommend.
  3. WillyEckerslike
    I don't use them enough to warrant buying a top brand model so I bought a Wolf machine (which came with a diamond blade). It has a rotating rear handle and has been excellent in use. I think it was £55 about 5 years ago. There's no case but I keep it in an old toolbag.
    Edit: I've actually used it far more than anticipated - hasn't missed a beat.
  4. KIAB
    KIAB Super Member
  5. Isitreally
    Isitreally Super Member
    Having used a few over the years, i can't fault Hitachi 9" grinders, i have used Bosch (OK). Dewalt (total rubbish).
  6. DIY womble
    DIY womble Well-Known Member
    Ebay for me
  7. DIY womble
    Paid £45 for 1600W China cheap plaster mixer , 3 yr ago , on my 3rd set of brushes , noisy but has done all I've asked , less of a worry about theft , just like push bikes
    Upgrade your specialized , Marin, trek etc
    Get rid of the name
  8. teabreak
    Thanks for all the suggestions. I would go for a bosch blue if it was for heavy use, however I was thinking about a basic wickes or screwfix one as it is really a one off job. Anyone tried either? Certainly want a soft start with the larger disc;).
    Slight hiccup with starting though, moved 49 slabs through to the back today last one on the pallet was broken, bent down to pick it up and my back gave out not even a full slab!o_O:(
  9. DIY womble
    Bit silly that , why didn't you get the wife to move them
    gadget man, KIAB and teabreak like this.
  10. mcooper2406
    mcooper2406 Active Member
    I bought the erbauer one. I don't usually go for them but as with you I wanted this to remove a couple of walls in my house where grinding from both sides would make too much of a mess of it!
    It is soft start and has a rotating handle. No problems with it at all, although as I've said I've not used it much! Hope this helps!
  11. DIYDave.
    DIYDave. Screwfix Select
    With all due respect to above posters, recommending several top end grinders for what you've made clear is gonna be a one off job with perhaps occasional use is nuts :eek:
    I'm only surprised nobody has suggested you go Festool for this job (don't actually know if they make a 9" grinder but if they do, agreed it will be bluddy good and several hundred pounds - makes perfect sense) :D
    Anyway, go for SF own brand, the mighty Titan;
    https://www.screwfix.com/p/titan-tt...0v/40362#product_additional_details_container
    Its rather heavy, built like a tank, comes with a decent case, long lead, and a 2 year guarantee, soft start, multi position side handle (but a s hit blade)
    Spend a few more quid on a segmented diamond blade and corny yes but 'hot knife through butter' will flash through your mind
    Yes but peeps are gonna say - there's no after sales service, no spares available, no fancy brand name to show off and brag about, no free t shirt, etc
    Again, 2 year warrenty, generic brushes are available if need replacing some years down the line and apart from that, it will do the job fantastically
    buy the Titan, you wont be disappointed :D
  12. DIYDave.
  13. KIAB
    KIAB Super Member
    My Hitachi was new & boxed & came from Freecycle.:eek:
    teabreak and DIY womble like this.
  14. KIAB
    KIAB Super Member
    Good blades, as are the Nortons.
  15. KIAB
    KIAB Super Member
    Hire a grinder for the weekend or week, hire use to be around £15 for a week.
  16. Mr Rusty
    Mr Rusty Screwfix Select
  17. DIY womble
    Even i cant do a £15 a week holiday
  18. teabreak
    Thanks guys, Guess I had better take the wife with me to buy the grinder to check she can handle it!:p:p:p
  19. Isitreally
    High end, expensive. ???
    https://www.toolden.co.uk/power-too...-cwwuB-RDJICojBxfzCkG1rlh1TFf3eQaAvg8EALw_wcB
  20. KIAB
    KIAB Super Member
    teabreak likes this.
