Laying ducting for electricity cables
Discussion in 'Builders' Talk' started by Mili62, Jan 11, 2019.
  1. Mili62
    Mili62 New Member
    Need to lay ducting to bring electricity connection to my newbuild house next week .will be around 50metre of 2 inch ducting going down. Need to bring roped through and wondering what the easiest way of doing this as never done it before. I'm sure people who do it all the time have an easy way of doing this
  2. dobbie
    dobbie Well-Known Member
  3. Rulland
    Rulland Well-Known Member
    python-rod-500x500.png You can get ducting with a draw wire already in, may have to use that to pull a more substantial rope in for final armoured pull.
    Or hire a python for a day.
  4. 14th edition
    14th edition Well-Known Member
    Armoured will rattle through there no problem!
  5. Jimbo
    Jimbo Active Member
    Could try suck a string or fishing wire through with a vacuum then pull a draw rope through with that. At 50m and 2" might need something we a fair bit of suck though!
  6. stevie22
    stevie22 Active Member
    Tie a carrier bag to your first line. That should let you build up enough suction
