Laying ply over floorboards
Discussion in 'Builders' Talk' started by Alan Jones, Nov 8, 2019.
  1. Alan Jones
    Alan Jones New Member
    Hi
    I have an upstairs bedroom and the floorboards are not in great condition (gaps and not very level). So before we put laminate down I am going to cover the floor with sheets of 12mm ply. Question is, If I screw every 150mm on the ply, do I need to leave an expansion gap around the edges, like I would with the laminate? The laminate will be floating, so no nailing or gluing it.
    Thanks, Alan.
  2. Astramax
    Astramax Screwfix Select
    No gap just nice and tight butting up to each board. 150mm is correct and 100mm around the perimeter of each board, choose a screw that will not go the full depth of the floorboards due to any pipework or electrical wiring that may be underneath.
  3. Alan Jones
    Cheers Astramx, and butt up to skirting board too?
  4. Astramax
    I did leave a small gap of about 2mm and cut the architrave to slip the ply under.
  5. Alan Jones
    Great thank you for your help
