Leak on boiler
Discussion in 'Plumbers' Talk' started by Rodduz, Dec 2, 2019.
  1. Rodduz
    Rodduz New Member
    Hi,
    Got a leak on my boiler, a glowworm betacom 24c. Anyone have an experience with these?
    Have had a F75 fault a couple of times in the past which is the pressure sensor but if I've bled the attic rad the fault goes away.
    Leak is coming from the pressure sensor, have had it taken off PTFE put on it and seemed to stop it but still had fault code. Bled the rad, code went away but started leaking.
    Will replacing the sensor do the trick?
    Have video of the leak but won't upload on here for some reason
  2. kiaora
    kiaora Screwfix Select
    hi
    its not safe to play with a boiler if you don't know what you are doing,
    some things leak by design to avoid going bang !
    get somone who knows whats happening
    good luck
    peter
  3. Rodduz
    Rodduz New Member
    Haven't touched it. My mate who's a plumber did it earlier but as it's still leaking he said see if I can find out anyone who knows glowworms first before buying a new part as he not familiar with them
  4. kiaora
    hi
    i thought the pressure sensor was an o ring seal ?
    can't put ptfe on that
    good luck
    peter
  5. njjea
    njjea New Member
    We had that issue BG changed the sensor & then the pump. Does the pump sound healthy ? We have their service contact so it was covered. Winter is genre and every house we lived in boilers only tended to play up when it’s cold
  6. Rodduz
    Rodduz New Member
    Apparently it's a diverter valve or something, just ordered a new one. We shall see ..
  7. Rodduz
    Rodduz New Member
    Erm I think it sounds healthy yes or sounds like it always has done. Won't be getting a GW worm again.
