Led downlights
Discussion in 'Electricians' Talk' started by Pete1981, Mar 17, 2019.
  1. Pete1981
    Pete1981 New Member
    Afternoon ive Moved into a new bungalow and led downlights have been installed with insulation put over them , do these need to have some sort of hood over them ? Is there a cheaper alternative to the expensive hoods ?
  2. KIAB
    KIAB Well-Known Member
    Clay flowerpots.:)
    seneca likes this.
  3. Heat
    Heat Well-Known Member
    I believe the led 240 volt lights don’t have to have insulation kept away from them, but I am not an electrician and will be interesting to hear what the Pro sparks say
  4. Heat
    Yes, have seen that done with halogen downlights.
    Simple solution.
    But not required on led I think?
  5. KIAB
    Some led fittings can be covered with insulation, others can't.
    Trouble is,if fitting is a GU10, then someone might remove led lamp & a fit halogen GU10 instead.
    Heat likes this.
  6. Heat
    Makes you wonder why downlights that cannot be covered with insulation are allowed to be installed in bungalows or on other ceiling directly into attics.
    Silly that insulation depth has to be to regs, but at each downlight no insulation
    KIAB likes this.
  7. Heat
    Good point. And often a job many clueless homeowners will tackle, oblivious to bulb type.
    If the OP knows the type of downlights, then that will give the answer to insulation query
    KIAB likes this.
  8. KIAB
    Crazy situation.:rolleyes:
    Heat likes this.
  9. Heat
    I always thought downlights were stupid, unless on ceilings that were very low, or lower floor ceilings.
    There is a gap in the downlights that allows hot air to escape, so not exactly energy saving. And at as much as 50 watt each, the halogen bulbs power consumption is crazy, just for a torch like restricted beam
  10. KIAB
    Was in house last week & in kitchen they had about nine downlights, huge things about 125mm diameter, with the R80 100w reflector lamps in a kitchen!:eek:
    They were done by previous owner, & the young couple had just bought house & these downlights were the first job on list to replace, but what surprised me was how dark my reactolite glasses went.
    Heat likes this.
  11. Pollowick
    Pollowick Well-Known Member
    R80s had a narrow beam too, there was at one time an RO80 which had a much wider beam that meant less were needed to get a decent light level at head height. There are now LED versions of the R80 to which can be a quick and easy replacement.
  12. Pete1981
    Pete1981 New Member
    The lights that are fitted are ksr
    Can i i completely cover these pots with insulation ?
  13. KIAB
    I lay insulation all around flower pot & just leave the hole exposed.:)
    seneca likes this.
  14. seneca
    seneca Screwfix Select
    That's how I done it with Halogens but now with led's I don't think it matters, just go over the whole lot?
    KIAB likes this.
  15. KIAB
    If fitting is GU10, then I leave hole exposed in case,someone decides to fit halogen lamp, but something like a Halers H2 fitting, then covering completely shouldn't be a problem.
    seneca likes this.
