Ledger board for decking
Ptdmitchell
New Member
Hi all,
I've decided to build a deck at the rear of my propert but need some advice on the best fixings to attach the 6x2" ledger board to the wall. I've used 6x130 screws with 3x3mm M8 square plate washers behind each screw to leave a 9mm gap for drainage. The screws I've used have pulled in tight, but not as tight as I'd like, and are pulling into the wood. Should I use something like coach bolts instead to get a real firm fixing? Any advice would be welcome
Many thanks
If the masonry is friable, resin bond threaded rod into the wall using nuts and washes to create a gap, they will not pull out like plugs sometimes do. If the masonry is sound use masonry bolts that screw straight into drilled holes.
Back
Top
