Legend Fire power flue no green light, no gas
Discussion in 'Plumbers' Talk' started by JamesN, Sep 8, 2018.
  1. JamesN
    JamesN New Member
    Hi all, just purchased a house with a legend fire. Turn on the fan and air is being pulled. Pilot sparks but won’t light, no green gas light next to the fan switch. When it worked the green light was on. Any ideas?
  2. KIAB
    KIAB Well-Known Member
    Gas turned on at meter.
  3. JamesN
    JamesN New Member
    Yes was working yesterday.
  4. kiaora
    kiaora Well-Known Member
    hi
    don't play around with it,
    get it checked out, by engineer.
    can be dangerous !
    regards
    peter
  5. JamesN
    JamesN New Member
    I was looking for advice on potential causes such as APS or common / intermittent faults on the power flue. Power flues aren’t the most efficient fires and parts seem to be obsolete. But if you don’t know about legend fires and power flues I would rather you didn’t respond. Don’t play with it isn’t very helpful. Parts are clean so I suspect either an APS or board issue but I would value opinions.
  6. Bob Rathbone
    Their will be a flap in the airflow to the flue that is lifted by the air being moved by the fan, check to see if this has stuck closed. Probably be located in the fan box outside.
  7. JamesN
    JamesN New Member
    Will do thanks for the advice. I’ll feedback tomorrow cheers
  8. kiaora
    That’s me told off then!
    It’s just I don’t like that type of fire, that’s all..
    Some people have died using that type of fire. When the proving sw failed..
  9. spirits are real 2016
    spirits are real 2016 Active Member
    is the gas meter pre payment or smart meter
  10. JamesN
    JamesN New Member
    Telling off brilliant, Not my intention. The fire must be getting to me .
    Gas is on mains supply. It was working for about 5 nights but then the gas green light wouldn’t come on when I turned the power flue on. We are semi rural so will check the box on the wall but it’s screwed and siliconed to the wall so a trip to the shop first.
    Don’t mind cleaning or an easy fuse swap etc. But won’t play with settings or gas.
    Legend suggested 3 sharp blows near the pilot?
    Gas engineer has suggested the board on the power flue control box which is obsolete? New fire recommended. He didn’t check anything else.
    Thanks chaps
  11. KIAB
    New fire, the best & safest idea you have had.:)
