Levelling Floor after removal of brick TV Unit
Discussion in 'Other Trades Talk' started by Jameses, Mar 21, 2018.
  1. Jameses
    Jameses New Member
    I removed a brick TV unit from the living room of my house which has left a channel in the floor where the bricks sat, would you use a normal cement mix to bring it back up to the correct level or self levelling?
    [​IMG]
  2. Dr Bodgit
    Dr Bodgit Super Member
    How deep is it? Probably use a sand/cement mix unless its really shallow.
  3. Jameses
    Jameses New Member
    I would say at its worse its probably a couple of inches deep. Would you use sand and cement or just cement?
  4. Dr Bodgit
    6:1 sand and cement, a mortar mix. Definitely not neat concrete.
  5. Jameses
    Jameses New Member
    Thank you
  6. Dr Bodgit
    Or may be 4:1, its a standard screed mix.
  7. goldenboy
    goldenboy Super Member
    I would Use Wickes Deep Base levelling compound if its just a shallowish channel. Have done this a few times when frames have been taken out and there is a threshold/sill to make good.
    Dr Bodgit likes this.
