Hi all. We've just had a wall moved which has made a room larger on the ground floor. The room had previously been fitted cork floor tiles which we carpeted over when we moved in. Moving the wall has left a strip of bare concrete floor approx 1.5 metres wide along side the new wall. I've lifted some of the old damaged cork tiles to leave a neat edge. So far as I can tell the remaining cork tiles are well stuck down. I'm thinking of using levelling compound to bring the new floor level with the existing cork tiles ( not over the tiles obviously). Reckon the screed would be 2-3 mm. The alternative would be to have to remove all the tiles from the rest of the floor which would be a swine of a job. I'm then going to have a new carpet and underlay put down on top. Any thoughts? Do you reckon having these two surfaces butting up against each other will be OK? Cheers
