anybody had any issues with Leyland acrylic bubbling in random places when used over oil based undercoat on walls....???
You can use oil base on top of water base but not the other way around because the oil gases off causing poor adhesion for a water base paint and the bubbles are the trapped gas.
I see, so what would you use to go over the top of it? also thought it was a trick to use oil based undercoat over caulk before top coat to stop cracking and crazing...?
You need to get the acrylic off, it will probably wash off with warm soapy water and a scotch bright sponge. You will probably get away with painting over the undercoat with Zinsser Cover Stain and when fully dry use the Leyland acrylic. Try a test area first but I'm sure this will solve your problem.
I prefer adhesion primers over oil based paint, but a good de gloss with 180g and then a wash as surfaces needs to be clean, then I'd wipe over with liquid sanding solution prior to my chosen waterbased primer. Acrylic primer undercoat should stick fine with proper prep. Get the duck tape ect out and pull/peal it off then try again
thanks for the advice, im getting lost with this to be honest, people have advised to use an oil based under coat to combat problem walls etc... now im being told not to put water base over oil based... this wall was stripped, filled in places, patch plastered in others, got it fairly smooth, scraped away any lose or flaky areas, sanded the edges of these back and spot primed the areas with BIN, filled over the top and made smooth, primed the bare plaster with Gardz, painted the entire wall with Johnstones oil base undercoat, filled over any slight imperfections and made smooth. then I rolled on a couple of coats of Leyland trade acrylic, all fine . Then i rolled on a coat of armstead trade matt emulsion - it was only then that this infact bubbled in certain places - not mega bad, maybe 4 or 5 spots, I let it dry and all calmed down apart from one bubble. when I put the scalpel to this I could get down to what I think is the oil base....
Has it bubbled to oil based primer or back to plaster. Think your problem may have been leaving something on the surface. Not getting it all off as needs to get the lot off back to good sound plaster. Acrylic primer. Fill. Sand. Primer. If stains or any bleed through then coverstain but leave a week to cure, then emulsion. Oil based undercoat you used has no stain blocking properties unlike coverstain. I used Johnstones waterbased stainaway now vs solvent if I can. Much nicer
Astra you are the one that put me on to using an oil based undercoat to cure all sorts of issues with problem walls
That is totally untrue. Identify the post, you have obviously misread something. If you are referring to oil based primer sealer that is and would be used for a different problem.
Adamfya your post 22nd November re Gardz/Peel Stop, I recommended oil based primer sealer not oil based undercoat which is a totally different product!
What was the initial problem with the wall that made you use product after product after product ? I appreciate you’ve been seeking advice and may have followed some/all and/or got a little muddled From your list of stuff you’ve hit this wall with I’ve noted; Zinsser Bin Zinsser Gardz Oil Based Undercoat Acrylic Undercoat Matt Emulsion So just what was the issue with this wall ? ps. Does the room feel a tiny bit smaller now after all those coats
well, just removed wall paper and was left with a wall that needed a bit of filling and a bit of patch work with plaster, some flakey areas of paint etc.....
ok guys, so now you have established I've been using the wrong stuff and making a right pigs ear of this job, tonight, I've damped down the wall and scraped off all paint + acrylic primer right back down to the oil based undercoat. Apart from where ive nicked the wall with the scraper, the oil based undercoat seems to have adhered well to the wall and any filler or plaster areas... I was planning on leaving it to dry now, and then giving it a quick sand down with the d/a tomorrow night. I am a bit reluctant to try and remove the oil undercoat as I think it will bring half the wall with it!!!
