Light bulb will not light up
Discussion in 'Electricians' Talk' started by geoff1962, Jan 9, 2019.
  1. geoff1962
    geoff1962 New Member
    No its a bayonet type
  2. Mikl8891
    Mikl8891 New Member
    So Often happens, the metal on the spring over time "gets tired" and badly pressed against the light bulb.
  3. spirits are real 2016
    spirits are real 2016 Active Member
    check the voltage at celing rose on incoming cable live and neutral before switch
  4. Bazza
    Bazza Well-Known Member
    WWhen you did your voltage test, were you testing between the two reds, or between one of the reds and soemthing else?
    If you are voltage testing at the switch, suggest you test between earth and line. It doesnt sound like you have a neutral at the switch.
  5. geoff1962
    Thanks for all your help
    it was the neutral on the light before
  6. spirits are real 2016
    just goes to prove many hands make light work.
  7. Bazza
