View attachment 59878 Hi All, Another question re the light fitting in the photo. I have wago connectors, but I just want to make sure i wire it up correctly. i only have the 3 terminal wagos, does that matter if only use 2 of the slots? Either way some advise on how to wire this to a downlight would be ideal! As im more confused with this vs standard rose etc thanks
No you don't have to use all the slots of a wago. You need to put the connections in a wago box, with a short piece of cable to your new light. The 3 reds are looped live in 1 x wago The 2 blacks are neutrals in 1 x wago The 1 x black is switched live (should be sleeved brown or red) in 1 x wago. Then take your new piece of cable from live neutral and earth. Earth will be a bare wire sleeved green and yellow it's probably tucked up in the ceiling. Obviously turn the power off before doing this.
