Light Fitting to Downlight - Wiring / Wago
Discussion in 'Electricians' Talk' started by LukeSki11, Jun 30, 2021.
  1. LukeSki11
    LukeSki11 Member
    Hi All,
    Please see photo of current wiring in place for a hallway light fitting.
    I’m not a sparky but is that the right setup, neutral connector to live?
    Either way i’m looking to change it for a LED downlight and have various Wago connectors.
    please advise best practice to wire this correctly?
    Thanks!
  2. Ind spark
    Ind spark Screwfix Select
    It's not a neutral it's switched live, it needs red/Brown sleeeving on it.
  3. LukeSki11
    LukeSki11 Member
    Okay thanks! The downlighter has a live & neutral into a block, could I just run the neutrals/switched live straight into the downlighter block?
  4. Tricky Dicky
    Tricky Dicky Screwfix Select
    Hi, I'm only DIY, so ...
    The reds are live conductors,
    The blacks/Blues are neutral conductors,
    The black/Brown wire is the live return from the wall switch, (and NOT a neutral connector) the black wire should be sleeved with a red or brown sleeving to indicate its status.
    The Green/Yellow sleeved are earth, please connect these together properly - your life might depend on it one day.
    Original wiring might be DIY rather than a professional electrician.
  5. Tricky Dicky
  6. LukeSki11
    LukeSki11 Member
    Hows best to terminate the earth in a downlight which doesnt have an earth connection?
  7. DIYDave.
    DIYDave. Screwfix Select
    Great that you have Wago connectors, various ones even !!
    But, you also need an enclosure to put them into - not just stuffed into the ceiling cavity like this connector blocks are (as in millions of homes across the country)
    Unlikely you have red/brown sleeving to hand and unlikely your gonna buy 5m when in reality you need 25mm
    Either red/brown tape or at least masking tape coloured in with a felt tip
    Most important you don’t mix up the single black wire with the others so mark it before doing anything else
    Obviously power OFF before touching anything and check circuit is dead and nobody in the house will flick fuse back on without you knowing it (when they find the lights aren’t working)
    The Earth cores, and there should be three separate ones there, should be terminated together as simply as the three reds are (which are permanent lives to other rooms)
    I’m guessing they’ve been simply twisted together and sleeved over, not great for Earth continuity (hugely important even if your downlight doesn’t require an Earth connection)
    So, terminate all three earths outside of downlight by using either a 3 port Wago or the same channel of a connector block. Each one individually sleeved is much nicer also :)
  8. Tony Goddard
    Tony Goddard Screwfix Select
    The three existing cables need to be joined in a junction box with another short length of cable connecting that to the new downlight.
    An Ashley/hager J501 would be good for this purpose.
    Not sure why you have cut out a chunk between the old cable hole and the new light hole. Would have been better to label the cables, disconnect them and pull them through.
    The Happy Builder likes this.
