I need to replace this light , but I can’t find an exact match for it on Screwfix. Could anyone recommend one on Screwfix that will be replacement for it ? Make/model is: Sylvania f58w/135 t8 Standard 5ft Thank you
You want colour number 835 white which is the replacement for number 135. Screwfix do not seem to stock it. https://www.easy-lightbulbs.com/lig...tubes-26mm/2-pins-at-either-end/f58t8-835-sy/
Thanks but would this work: https://www.screwfix.com/p/sylvania-luxline-plus-g13-t8-fluorescent-tube-5200lm-58w-1500mm/46681
