Hi, I'm not an electrician, but I have added sockets and lights in the past etc.. Anyway, in one of my rooms I have a 4 gang 2 way light switch which controls 12 halogen downlights - each one 50 watts mains power. (Three downlights on each switch). The faceplate has a crack on it after being hit when moving furniture and so I need to get a new one. I notice Screwfix only sell 4g 2w switches that are called 10AX switches for this 4g size. I have looked inside the face plate and the wiring is very straightforward. My question is will this 10AX be ok or is this just for flourescent lights or inductive loads, (not that I know what inductive means)? I work out the power to be 12 x 50w = 600watts. This is less than 3 amps. I just don't know what the X in 10AX means and if it will be a suitable replacement for the existing damaged switch. Please help if you can.
