Hi all,
I recently moved into an ex LA house and was removing a 2 gang light switch for decorating. I noticed something strange with the wiring so thought I would see if anyone can explain it to me. Hopefully it's a pretty straight forward one.
The 2 gang light switch is in the kitchen. The left gang switches on the kitchen ceiling light and the right gang switches on the outdoor lights.
The incoming wire is a 3 core and earth cable. The main lights are on a live and switched live leaving the remaining core located on the COM to the outside light.
There is then a short wire that jumps from the outside light's L1 back to the kitchen's live COM. I have attached a simple diagram (apologies only had a black and brown pencil to hand.
Also I would like to install one of those Quinetic switches for the main kitchen light and I know I have to install a receiver but not sure how I should incorporate that to the above? Any advice would be good.
TIA!
TIA!
