Light with a connection. Block
Discussion in 'Electricians' Talk' started by JDB74, Jul 30, 2022.
  1. JDB74
    JDB74 New Member
    Hi all. Having problems with a light fitting with a connection block. This connection block has three ports. The instructions are telling me reds together blacks together and earth together however playing havoc with upstairs lighting... Any ideas
  2. terrymac
    terrymac Screwfix Select
    Pics of your wiring at the ceiling, and the light fittings terminal block would be helpful.
    Do you have any voltage testing instruments ?
    How many red wires,and how many black wires are present ?
  3. JDB74
    JDB74 New Member
    That would have been useful... 3 wires 3red/3black/3earth. I do have a voltage checker but I think but vever really used it.
  4. terrymac
    The 3 reds go together in an insulated terminal block ,and do not connect to the light fittings terminal block. One of the blacks is likely to be the switched live and may have a bit of red tape or sleeving on it to denote it is such, and you will need to establish which of the 3 blacks it is, as it goes into the live terminal of the light fitting. The other 2 blacks are neutrals and go together into the light
    fittings neutral terminal.
    And of course all earth wires connect to it's earth terminal.
  5. JDB74
    JDB74 New Member
    Thanks so I should have 4 port terminal block than rather that the 3 supplied
  6. terrymac
    Yes ,or an additional single connector block.
  7. Ind spark
    Ind spark Screwfix Select
    When you say playing havoc was it tripping the breaker?
  8. JDB74
    JDB74 New Member
    Sometime yes and othersbwith lights not working.. Just connecting up as terrymac as suggested and will retry
  9. Ind spark
    Arr ok, terrymacs right.
  10. JDB74
    JDB74 New Member
    So I have all 3 reds in one block all the earth's in one and I have switched around all 3 black wires into the live block to the pendant and no lighting apart from one which must be the start of the loop.. Frustrating
  11. Ind spark
    Like this?
    When you put a black in the live you are putting the other 2 to neutral I assume?
  12. JDB74
    JDB74 New Member
    The fitting is connection blocks rather that a rose
  13. Ind spark
    Post a picture how you have it.
  14. JDB74
    JDB74 New Member
    Due to cable length I have had to seperate out block
  15. JDB74
    JDB74 New Member
    Wondering if I have moved some connection in the loft prehaps
  16. Ind spark
    Your connections don't look great.
    Also you need to sleeve the earths green and yellow.
    Do you have any testers?
  17. JDB74
    JDB74 New Member
    Yes but wouldn't now how to use them.. Got given them
  18. terrymac
    Show us a pic of the tester/s. You need to establish which black wire is the switched live, and if you have fried the switch when you previously wired up incorrectly and tripped the breaker
  19. Ind spark
    If your not confident might be the time to call an electrician.
    If you want to try turn all the power OFF, separate each red and black into pairs, set your tester to continuity and put the probes on red and black then operate the light switch ( you might need help for this) the one that makes the tester bleep on and off is the cable to the light switch.
  20. JDB74
    JDB74 New Member
