Lighting
Discussion in 'Electricians' Talk' started by snipper1, Feb 29, 2004.
  1. snipper1
    snipper1 New Member
    Now about to re-wire the upstairs lighting......
    Q.Want to add x2 loft lights in the circuit, how can i wire x2 lamps on same switch
  2. gerrin2owd
    gerrin2owd New Member
    Take the supply T&E(LNE)to the loft switch, take a T&E from the switch to 1st light then another T&E from 1st light to 2nd light. The connections at the switch are as follows, red supply to switch connection, red (switchwire) to other sw connection, 2 blacks into a connector, earths (cpc's)to earth terminal.
    Or,
    Take the supply T&E(LNE)to the loft switch, take a T&E from the switch to 1st light, take another T&E from switch to 2nd light. The connections at the switch are as follows, red supply to switch connection, reds (2-switchwires) to other sw connection, 3 blacks into a connector, earths (cpc's)to earth terminal.
