Lining paper, which way up?
Discussion in 'Other Trades Talk' started by Clarts, Mar 27, 2006.
  1. Clarts
    Clarts New Member
    How should lining paper be hung if it is to be just painted over? Horizontal or vertical?
  2. MOONSHINE
    MOONSHINE New Member
    I find it easier to hang down. sometimes skim down the line with polyfiller then sand lightly. Or just sand joints lightly to blend in. There are different grades of paper.
  3. Lightning McQueen
    Lightning McQueen New Member
    Vertical for painting, horizontal if papering.
  4. Burlington Bertie
    Burlington Bertie New Member
    Are you having a laugh?
  5. Lightning McQueen
    Who??
  6. Ceramic
    Ceramic New Member
    All depends which way round......................:)
    Do you put it on back to front?..................:)
  7. trustedman
    trustedman New Member
    hang it vertically, for painting much quicker and easier. Butt the joints up, no need for filling or sanding the paint will fill and hide the joint, ignore the leave a 1mm gap in the instructions as this is only if you are lining under a wallpaper
  8. MOONSHINE
    Even butting the joints & painting 2 or 3 coats you will still see the joints on some of the walls. The paper shrinks when dry. My way is longer but better results, looks like new plaster walls my way.
  9. MOONSHINE
    & never skimp on the price of paint, cheap trade paints from diy stores are ****. Used cheap white on light green once 4 coats later still showing. \just use Dulux now.
  10. Burlington Bertie
    Rubbish. If the lining paper is done properly i.e. butted properly, you will not see any joints after 2 coats of emulsion. Someone said in a previous posting that you should ignore the 1mm gap in the instructions because this is only done when your are papering over the lining paper with wallpaper. Where did he get that rubbish from?? I have been using lining paper for 40+ years and never heard such cr*p. Also, the lining paper does not shrink when dry. Why do people who know nothing give advice??
    Be kind likes this.
  11. trustedman
    you
    The
    better
    as I said burtie just butt the joints, if you paper over you leave a 1mm gap so as to not get a ridge. You dont sound like someone with 40 years experience
  12. MOONSHINE
    Your telling me all the work you do is perfect. The paper will shrink 1mm there is movement in the walls joints open. Why do you think so much work goes into drywall joints, & thats with plaster on top not 2 coats of paint. I do it my way because that is the best finish for me. Never ever see one piece of joint showing anywhere. Next time have a good look at your seams.
  13. MOONSHINE
    When you put on paste paper expands, if you don't let it sit the paper will shrink on the walls.
  14. Burlington Bertie
    Clarts. As I said before, ignore this rubbish advice from Timillfixit and Belinda. Neither has a clue. Look up the web site 'experts guide uk' then wallpapering. It offers fairly good advice.
    Suggest Tim and Belinda might learn something from it also.
  15. Burlington Bertie
    Tim, if a professional decorator such as me bit your a*se you would'nt recognise him. If you are a decorator in my area, I need not worry about competition from you. You aint got a clue. If you butt the lining paper properly (whether you paint it or put paper over it) you will not get a ridge. How the hell can you get a ridge if the lining paper is perfectly flat ??? You are more likely see a ridge under your finished wallpaper if you leave any size gap.
    2
    posting
    are
    Where
    cr*p.
    Why
    you
    The
    better
  16. Burlington Bertie
    Belinda my dear, I should give up now if I were you. Yuo are digging yourself deeper into a hole. How many rolls of lining paper have you hung/ 10? 20? How many rolls do you think a professional decorator of 47 years experience has hung?
    Your comments about wall movement were hillarious. And yes, all the work I do is perfect (as you claim yours is).
    I could show you photographs of ceilings and walls I have papered, but you would'nt see the joins Ha Ha
    I should stick to cooking and knitting if I were you, you havent got a clue about lining paper.
    r seams.
  17. trustedman
    hey burtie.
    **** off tosseer
  18. Tony Soprano
    Tony Soprano New Member
    :) how people manage to get themselves so irate about how they do things,look man who has been doing it for that many years aint gonna change ,and belinda if your happy doing it your way then so be it stick with it,as for the the fella who is looking for advice well you can always try both methods and see what u like
    ;) ps i wont say which method i prefer because i can feel some vibes here !
  19. mwfchris
    mwfchris New Member
    A point to add. You should never fill over lining paper directly, as it furs when you sand it. If for any reason you need to fill lining paper joins, do it when it has had a coat of emulsion. Another point a gap is better than a lap!
    Chris
  20. Burlington Bertie
    hey burtie.
    **** off tosseer
    Nothing like a good intelligent debate, Tim.
