Lintel advice
Discussion in 'Builders' Talk' started by smithybora, Aug 16, 2009.
  1. smithybora
    smithybora New Member
    HI Guys.
    Quick question.
    What lintels can i use for a single brick work.
    All i have seen are for a cavity wall.
    cheers
    tony
  2. N. Green
    N. Green New Member
    You could use a "L" shaped lintel. (similar to an angle iron)
    Should be available from any builders merchants.
  3. smithybora
    Thanks for the advice.
    Also just remembered google. Something came up called a
    Leaf Lintel. Think its like an L shape or either one that looks like a U shape. If i got that right.
    thanks
    tony
  4. hallbeck
    hallbeck New Member
    Or if the bricks are being rendered/plastered - use a concrete lintel.
  5. paddyodoors
    paddyodoors New Member
    how about using an arch
  6. ecm
    ecm New Member
