Lintol/Steel advice needed
Discussion in 'Engineers' Talk' started by Ian Mcmanus, Sep 11, 2021.
  1. Ian Mcmanus
    Ian Mcmanus New Member
    Hi
    I'm in the process of ordering materials for my attached garage build. Its a single story with a pitched tiled roof all the way round 3 sides. Tiled up to a height of 1 meter and then a flat rubberised roof on top of that.
    The front garage door opening will be 2.6m wide and either side and above the door will be a double skin solid wall.
    Question is, will I need a solid wall Catnic or an i beam with a plate on the bottom to support the bricks/blocks? The loading isn't huge but I'm just not sure what the reg would be on it and my plans don't mention it.
    Thanks in advance
  2. stevie22
    stevie22 Screwfix Select
    Ask whoever drew your plans. Probably a Catnic CN1B
