load bearing under stairs
Discussion in 'Carpenters' Talk' started by macliam88, Apr 21, 2021.
Tags:
  1. macliam88
    macliam88 Member
    Is this typically bearing any load of the stairs or simply a light studwork for the plasterboard that was attached to box in the bottom of the understairs before i stripped it all out?
    [​IMG]
    [​IMG]
  2. Jord86
    Jord86 Screwfix Select
    It's just to blank the bottom of the stairs off, nothing structural about it.
  3. macliam88
    macliam88 Member
    Thought so thanks
