Loft aerial problems! amp?
Discussion in 'Other Trades Talk' started by mattymtyuk, Jan 9, 2007.
  1. mattymtyuk
    mattymtyuk Member
    Hi all ive just put the high gain aerial (http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=A331867&ts=65656&id=30515) in my loft but i am still getting an awful picture and the signal bar on the freeview box is about 4% along, it was better with a **** indoor aerial! ive checked the connections and all seem ok, will an amp make a significant improvement or not? ive tried aiming it all directions as well!
  2. britishblue
    britishblue New Member
    There is no comparison between the reception you will get from an aerial in the loft and an aerial on the roof. I think you would be better off getting a professional aerial company to install the aerial on the roof. They also have the correct equipment to measure the signal strength and orientate the aerial for the best reception.
    BB
  3. M.I.G.
    M.I.G. New Member
    using good quality copper shielded coax cable will help, the cheapo stuff is naff.
  4. Mr GrimNasty
    Mr GrimNasty Active Member
    I bought the same one Matt, put it in the bin (like I did coz I was too busy to faff around) or send it back. A bit of coax slung over the roof gives better reception - looking at the connecting box on mine (1) I could see no way that the coax actually made contact with any metal part of the aerial (2) the tread was stripped so was unable to hold it tight anyway. Utter C R A P.
  5. hab
    hab New Member
    It really does sound like it is a duff aerial - can you receive analogue TV at all? Make sure the cable is good quality and make sure no strand of the outer shielding is touching the central core at the connection at either end as this fault would produce exactly the result you describe.
    I know this is an unlikely error but are you sure you have the aerial polarised correctly? If you are receiving from a main transmitter it should be horizontally polarised.The opposite is true if you are using one of the lower powered "satellite" transmiters - but you need to check. Details will be on the BBC website.
    I have a loft aerial with no amp and I am in a fringe area with low signal strength but I rather surprisingly get good Freeview - the quality of the signal (its freedom from interference) is just as important.If a signal is poor quality amplifing it will just amplify the rubbish as well.
    Regards, Hab
  6. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    You really have to take the whole set-up up into the loft with you.
    Take the telly/freeview/amplifier/all plugs etc connect it up to the coax that it will be using and move your aerial around the loft to get the right position/height/direction, while the telly is in full view.
    One tip, set it all up from your main aerial first, so that you KNOW the channels are set correctly before you start.
    Problem with aerials, is that there are specific kinds for specific problems. High gain is not always the best option etc.
    I used our old aerial (when we upgraded our rooftop aerial) in the loft, amp at one bedroom TV, and it supplies 2 TVs, 2Freeviews, 2 videos. Perfect reception all round.
    Mr. HandyAndy - really
  7. Mr GrimNasty
    On my example, in the connection box there was a small bit of 'circuit board' containing the coax connectors. This board was attached to the dipole by 2 screws - the screws were clearly supposed to make a connection between the dipole and the board - they equally clearly didn't - possibly because the screwholes were too big.
  8. mattymtyuk
    mattymtyuk Member
    ive taken it all in to the attic now, i can get all the freeview channels on the winter hill transmitter which are broadcast in very high but really blocky on the on the ones broadcast in very low, can any one suggest an aerial then?
  9. hab
    hab New Member
    Kandy,the circuit board you mentioned is the "Balun" (the balancing transformer).Its used to connect the BAlanced aerial to the UNbalanced co-axial cable.It should be the sign of a good design but the SF example seems very cheap for 48 element aerial.It seems that the detailed design of the aerial has been skipped - a pity as a 48 element aerial should be about as powerful as you can get.Certainly it sounds in the original post as if there is a bad connection or short somewhere , providing the vertical orientation (polarisation) is correct !
    Regards, Hab
  10. hab
    hab New Member
    Matlymtyuk,what do you mean by "very high" and "very low".
    The Winter Hill multiplexes are transmitted on these channels 56 ,66,68,67,60 and 63 with horizontal polarisation - you may get some programs on 43 and 40 also.If you point your aerial at Winter Hill with the X shaped director elements horizontal do you get all the Freeview programs - there should be about 85 radio and TV.How many can you get?
    Regards, Hab
  11. mattymtyuk
    mattymtyuk Member
  12. mattymtyuk
    mattymtyuk Member
    link minus the comma! ^^^^^^^^^ thanks for all the help
  13. hab
    hab New Member
    ITV muxA and Mux B use a system of coding called "64 QAM" and the others use "16 QAM". The former enables more programs on the multiplex but is more difficult to get so it seems that your signal level is marginal. If you can borrow an amplifier that might work.Other than that you would get better reception by installing the same aerial externally - if that is possible!. Sorry that I cannot be of greater help.
    Hab
  14. mattymtyuk
    mattymtyuk Member
    would it be a great improvement outside or just a little bit?
  15. The Dormouse
    The Dormouse New Member
    It's not pointing at a cylinder, water tank or pipes is it? There must be something fundamentally wrong if you can rotate it from horizontal to vertical & make no difference, probably a connection. Check at both ends that a strand of wire from the screen has not strayed across to the centre conductor, shorting it out.
  16. hab
    hab New Member
    Outside installation should improve the signal strength considerably.You say that there was no difference if you oriented the aerial horizontally or vertically.Are you sure about this? If the aerial is vertically oriented there should be very little or no signal from the Winter Hill main transmitter.There should be a considerable difference if it is horizontal - what does the signal strength indicator on your box say in both these cases?
    You don't seem to be getting the signal that your aerial is capable of so, as "Dormouse" says above,check your connections at both ends and that the circuit board (Balun) at the aerial end is making proper contact with the aerial - a multimeter would help here.
    Regards, Hab
  17. Mr GrimNasty
    Hab, I'm working from memory, but on this aerial, is the balun supposed to be in contact with the dipole or does it work entirely on induction?
    In the middle of the balun board was an isolated metallic foil 'fat upside down U-shape' with connector for outer coax.
    The dipole was in two separate loops and these were apparently connected together by a thin foil strip around the edge of the balun which had the center coax connector attached.
    A screw at each corner of the balun board was apparently meant to connect each part of the dipole to each end of the foil strip - but there was no metallic contact. Was that right or wrong?
  18. mattymtyuk
    mattymtyuk Member
    Heres some pics of the aerial,
    http://i134.photobucket.com/albums/q98/mattymtyuk/P1110079.jpg
    http://i134.photobucket.com/albums/q98/mattymtyuk/P1110078.jpg
    if i flip the X shaped elements vertical or horizontal the signal strength stays the same, ive checked, re checked and checked again all the connections even put more copper in the connections! now i can get all but one load of channels which is the one with the itv's in it, on five i get a signal but the quality is poor altho it is watchable, on ch 66 itv (i think?)i can get a signal but no signal quality,i cant get any signal from moel yr parc cos of a big bloody mouintain! so im stuck with winter hill altho its 50km further away!
  19. M.I.G.
    M.I.G. New Member
    try pointing the aerial to the Wenvoe transmitter and run the coax through a booster before connecting it to the tv.
  20. Mr GrimNasty
    The X-shaped elements should be clipped upright regardless. The whole aerial is then twisted on its axis for hor/ver. It looks very cramped for space there, difficult to get good alignment/sufficient height I would've thought.
