Hi all. I hope I have posted this in the right place. It has been very windy the last day or so, and the loft hatch is making a hell of a noise banging and it has woke my daughter up a few times during the night. I definitely know is that as when I get up in the morning it's half on properly and half not. Im just wanting help/advise to try and sort this out myself with a quick DIY job! I don't know how many times of hatches there is but it's just a basic one that pushes up (like a thin bit of fabric/cardboard). Thanks.
If it’s really thin and lightweight sounds like either plywood or hardboard Can’t surely be fabric or cardboard can it ? But the above materials come at around 4-5mm thickness and to use for a loft hatch sounds a real bodge job If it’s a simple hatch that just pushes up into loft, then ideally use this as a template (if it fits well) and cut a new one using 18mm ply or MDF or chipboard Much heavier and won’t bang about waking up your daughter
With your type of loft hatch, it just drops into place so relies on the weight of the panel and gravity to keep it in place You’ve got airflow in the loft which is a good thing and correct - it keeps the timbers up there dry and ventilated But as the current hatch is super lightweight, it’s this draught that’s causing it to bang in the frame A thicker / heavier panel will cure this im sure - good luck
I think I'm going to get a 18mm thick MDF board as was suggested above, could I just stick some insulation ontop of the board with strong glue? Also, thank you for your suggestion!
It depends what insulation you use - something rigid would obviously be easier to attach and use. Then, depending on what you use you need an adhesive that is compatible with or, more importantly, doesn't attack the material. Double sided tape would probably be alright for most products. You can get pre- insulated ready made hatches if you want to go the whole distance. Our hosts sell a few.
Hi mate. I've been all over the place today trying to find some MDF boards, every Wickes and B&q near me, and nowhere has it in stock, the biggest thickness they have is 12mm and I know you said 18mm, would it be much of a different, obviously I know its 6mm but in regards to weight..
Depending on the hatch opening size (which can be altered if needed) you would be better off to buy a Manthorpe attic trap for roughly forty quid, they are a hinged dropdown type and come with insulation prefitted to the back. Saves all the faff, and by the time you buy a sheet of MDF, a 4' sheet of kingspan insulation, glue or double sided tape and paint it all to match you will be closer to double the cost of a new trap.
