loft power
Discussion in 'Electricians' Talk' started by bonkey dollocks, Nov 2, 2003.
  1. bonkey dollocks
    bonkey dollocks New Member
    is it possible(for ease) to feed a tv aerial amplifier in a loft from the upstairs lighting circuit on a 2 amp plug.
  2. seylectric
    seylectric New Member
    In a word, yes, but what do you mean by a 2-amp plug? Simply fit a fused spur unit with a 1-amp fuse. An aerial amplifier draws very little power.
  3. sparky (Original)
    sparky (Original) New Member
    just connect the fused spur into the loop terminal of closet pendent and use 1.5mm cable.
    i have seen people put a normal socket on the lighting circuit but this could lead to some one plugging in a drill for example
  4. bonkey dollocks
    thanks for a quick reply.The 2amp plug is a three round pin plug which will only go into the same socket.I thought of the spur but you would always get somebody tapping something off it,thanks again
  5. ban-all-sheds
    ban-all-sheds New Member
    You could use a socket, if you thought you would ever need to frequently plug/unplug the booster amp.
    But you would still need to use a fused spur to supply that socket. It's rated at 2A, but the lighting circuit you are tapping into is probably fused at 6A or 8A, and as those round-pin plugs are unfused, you wouldn't have the protection that it needs.
