Log Cabin Base ... Not Level. HELP!
Discussion in 'Landscaping and Outdoors' started by Chris Surrey, Sep 6, 2021.
  1. Chris Surrey
    Chris Surrey New Member
    Hi there. I have ordered a log cabin to use as a garden office. I plan to put it on a pre existing concrete base that used to have a shed on it. Now here are the two problems:
    Firstly I need to enlarge the base. It is currently 310cm x 240cm
    I need to add to the back and side to make it - 420 x 270.
    That I am less worried about. I can dig that out and fill it in with more concrete right?
    The main problem is the old base has a small slope (assuming it was to help drain water). Its about 25mm off on the spirit level. Sloping away from the side I need to extend from (if that makes sense?).
    Needless to say the log cabin's bearers need to be on flat level ground.
    Ideally I don't want to relay the whole base, but hope can I level the bearers safely in a way that will take the weight. about 1000kg.
    PLEASE HELP.
  2. jonathanc
    jonathanc Guest
    just pack the bearers out - will be fine
  3. Chris Surrey
    Thanks Jonathan, what would you suggest packing them out with? Plastic shims?
    Or something more?
