Looking for pipe with 90mm inner ø
Discussion in 'Plumbers' Talk' started by Boreal, Nov 26, 2018.
  1. Boreal
    Boreal New Member
    Any idea where I can find a plastic (or light-weight metal) pipe with an inner diameter of 90mm +/- 3mm? It's going to be cut to length and used for storing a camping stovepipe of all things.
    I've found pipes with an outer diameter of 90mm but the inner is then too narrow for my needs.
    Any ideas?
  2. KIAB
    KIAB Well-Known Member
    Length?
  3. KIAB
    ERW (Electric Resistance Welded) round steel tube is 101.60mm, outside diameter, but wall thickness is only 1.5mm.
  4. Heat
    Heat Well-Known Member
    Why not use 110mm soil pipe?
  5. Boreal
    Boreal New Member
    Sorry, the length I need is no more than 30 cm. It's basically one of these https://seekoutside.com/titanium-stove-pipes/ rolled on its short end for storage
    ERW round steel tube might work though I prefer plastic for the weight, but 110mm soil pipe is definitely too wide to fit the supplied sleeve
    If possible I'd like to get closer to the 90mm mark but that may not be an option
  6. KIAB
    A McAlpine WC-EXTB 3 1/2-Inch/90 mm Straight Extension Piecemight work.
  7. Boreal
    Boreal New Member
    That might work. How long is the non-threaded/grooved portion? Also, is it reasonably rigid? I'm looking to protect the stove pipe in transport so I can't have too much flex. Thanks
  8. Pollowick
    Pollowick Well-Known Member
    You can download a PDF from the McAlpine website and it usually shows all dimensions
  9. Boreal
    Boreal New Member
    Thanks. Did that and this would not work as the inlet is 110mm which would be too big. Any other ideas?
  10. candoabitofmoststuff
    candoabitofmoststuff Active Member
    What about a length of 110 soil pipe, slice a section out and the "snug it up" with big jubilee clips?
    Cando
  11. Boreal
    Boreal New Member
    It's just that 110mm would probably not fit in the storage bag that comes with the stove pipe. I don't think more than 100mm outer would work, ideally no more than 95mm. Thanks for the suggestion though
  12. longboat
    longboat Well-Known Member
  13. Boreal
    Boreal New Member
  14. Isitreally
    Isitreally Well-Known Member
    As daft as it might sound and it does, but what about a stainless steel thermos flask with the innards removed.
  15. Boreal
    Boreal New Member
    Well, it'd certainly protect the stove pipe in transport which is part of what I'm trying to achieve, but it's a little more DIY than I was hoping for. Not to mention that it's a waste of a perfectly good thermos :)
  16. Boreal
    Boreal New Member
    So the 100mm manrose pipe worked after a fashion. It's not perfect as it's a rather tight fit in the stove pipe storage bag, but you can't argue with £1.29. I'll be on the lookout for something a tad smaller, but thanks again for the suggestions in the meantime. It will do on my upcoming trips
  17. Jimbo
    Jimbo Active Member
  18. Boreal
    Boreal New Member
  19. KIAB
    Get a tube 3D printed, can be any internal diameter you like,even have one end sealed, or a screw cap.
  20. Boreal
    Boreal New Member
    That would, of course, result in a perfect fit but I thought 3D printing was still in its infancy and stupidly expensive. Any idea of costs for something like this?
